Turnout/Bunker Gear Dealer?
6 posts in this topic
:) Does anyone know a place in Westchester that sells firefighting gear (Turnouts/Bunkers) that is easy to drive to? :(
Easiest place for you would probly be AAA in North White Plains. However, gear is very expensive. I suggest you wait to be issued gear from your dept. That way you are conforming to their rules and regulations and there wont be any problems.
:) Does anyone know a place in Westchester that sells firefighting gear (Turnouts/Bunkers) that is easy to drive to? :lol:
depends on what brand you want, some of them will come to you.. NRFD uses morning pride, you won't get that at AAA. pm if you need contact info
NRFD...As stated, gear is very expensive, so you may want to do a lot of research and shop around! If you are a member of a Dept. (career or vol.), then your department should supply gear for you.
AAA in North White Plains is a great place for anything fire-service related that you may need. The guys there are great, they're real helpful, they have everything and the prices are great. But again, they deal with Globe, which is good gear, but as Truckie Buff stated, it depends on what you need/like.
If you're into Morning Pride, i would suggest trying Trilex in Passaic, NJ. They're not all that far away and alot of City departments deal with them. They sell Morning Pride gear and they always have a ton of it in stock. When i went for mine, the guy sized me up, went to the storage area and came out with perfect-fitting gear! They kept it so they would sew my name/dept. on the back, as well as add some other features i wanter. I had the gear on my door step 2 days later! They also do cleaning and all sorts of alterations/repairs on site. I believe the entire set of gear (coat & pants) ran me about $1,200.
Heres their info: http://www.trilexcleanfiregear.com/
Edited by BFD1054
If you want fast and easy on the pocket Fire End sells Lion who offer an express set of gear called Bravo Express. It comes with the pockets and trim already on it. It comes in standard sizes M, LG, XL & XXL, pants same way but reg inseam & tall. It takes about a week to get with the lettering on it.
My company just recieved morning pride from a rep through Firematic. They deal with all Carins and Fire Dex as well. They also have just about anything needed under the sun including Pierce Fire Apparatus.
