"Project Responder"
Check this website (and truck) out:
(I dont know what to think of this lol)
http://www.projectresponder.com/
We are transforming a 1987 Ford Superduty F-250 4x4 truck into the Ultimate Volunteer Firefighter's Emergency Response Vehicle. We have completely disassembed the truck down to the frame and we are nearly done re-building it from the ground up. When the project is finished, this big, bad F-Series truck will light up the night and roar down the road.
The goal of this undertaking is to completely renovate and transform a standard Ford truck with over a quarter million miles on the factory motor, into a show truck that will be equipped for nearly any emergency to which a volunteer firefighter might be called upon to respond. Once completed, the truck will be used to respond to fires and other emergencies in and around it's home base as well as to strut its stuff at various 4 wheel drive and firefighting shows around the country.
Project Responder will ultimately create a truck that will not only take ribbons at shows, but that can go anywhere and be prepared for nearly any emergency. When the truck is finished, it will have been stripped down to the frame and rebuilt from the ground up. There will be plenty of polished aluminum and flashing lights, but there will also be power to pull a house down the road and enough gear to outfit a small fire department. This truck will be the ultimate firefighter's response vehicle.
