RES20CUE
(Delivered) Montrose V.A. Engine 224
18 posts in this topic
County: Westchester
City/Town/Municipality/Dept: Montrose Veterans Affairs FD
Unit designation/identifier: Engine 224
Chassis & Body (or Aerial) Manufacturer and model: Ford F-550 (4x4)w/ Rosenbauer Body
Pump size, tank size (water/foam), aerial type & length: Pump= Waterous 1000 GPM; Water Tank= 300 Gallon
Status: Delivered
Notes: This vehicle will be replacing the current MA-28 (1998 International/E-One). Same concept of vehicle except with a "class A" pump. MA-28 only has a 500 GPM pump. This vehicle also is our EMS first response vehicle and Rescue. The last Engine 224 (1970 International/FTI) was replaced by MA-28 in 1998.
Spartan052, Res30cue, FF398 and 4 others like this
Has this been delivered?
Montrose VA just received their new engine today.
nice looking truck. will help out with the tighter arch ways on campus
Engine 224 is in service. It's been busy with some EMS calls.
how is it being used comapred to Engine 225? EMS first response and related?
Check out their website... under the "current apparatus" tab, it lists each trucks' specs, equipment carried and uses.
http://www.montrosevafd.com/
Edited by firedude
And that would have answered his question if the engine was on there...
Yes, however, it's replacing MA28 so it should have the same uses.
Edit: If you read the 1st post, It states it's uses (Medical, Brush, Rescue).
Edited by firedude
Here My Pic Of Engine 224 From The Tried City ST. Patrick Day Parade In Buchanan NY.
In this picture (post 14), is that a CCTV Camera directly in line with the deck gun?
Yes the camera was provide by the va police used in case a patient goes missing
That is a Sierra Pacific Infrared Multi-Sensor Imager, equipped with FLIR technology. So it can be used as a CCTV or Thermal Imaging Camera. It was not provided by the Police. The Police purchased 2 of them, and were not able to mount the 2nd one. It was then given to the FD, for use. This has multiple uses well beyond searching for a missing person. Just another tool that the VA Fire Department has in it's arsenal!
x4093k likes this
