Win97 / Pro-2055 Help
3 posts in this topic
I have Win97 (software) & a Pro-2055 Scanner
I also belong to RadioReference.com
I've downloaded the County's Trunked System & then entered;
470.000000 380 12.5
469.525000 380 12.5
476.075000 500 12.5
(into the "MOT Custom Trunking Table" - I also picked "Normal" not splintered
Still NOT WORKING????
(Thanks to Jack10562 that setup worked perfectly on my BCT-15 with Arc15 software)
ANY help would be GREATLY appreciated!
Thanks
Do you have the banks set for Motorola? And when you manually go to one of the Control Channel channels (470.575 or 476.2375MHz) do you hear the CC datastream? If you don't hear this "noise" you are not within range of the system.
Also assume you have entered all the frequencies mentioned in this thread EMTBravo Westchester Trunked System
post #60.
I'm not familiar with the Win97 software, but did you Un-check CC Only (Control Channel Only) when downloading from RR, and make separate banks for north and south?
I see now, your model supports CCO, so that should not be an issue...
